This is freaking awesomeI got this in American flag. There is different gen version you’ll need the 14th gen. The puddle light is amazingly vivid. The issue is on the passenger side which show the flag backward. Here is a photo of the 13th gen which is why it’s crooked. The 14gen is more straight. FYI I got it about 50 bucks from Temu.
If you install this I'm assuming you lose your mirror-based zone lighting?I wish we could get ones with the Lightning logo
Why? Isn’t this just effectively “changing the bulb” to one that has an image imbedded? I would assume it’s going to work the same.If you
These are design for the mirror that is not folded. The install is super easy, since you’re only changing the light itself without opening up the mirror cover. If you look under you’ll see a slit opening. Just need insert a small flat head to remove.
I would take another photo of the 14 gen version however I also installed the side underbody light which now make the flag not as vibrant.
I ordered it on Temu. Checked the vendor and they’re out of stock was under 50 bucks total. But I find another from aliexpress more expensive. They have 13th and 14gen listed together so need select the correct one.can you post a link to the 14th gen ones? I cant seem to find them. thanks
https://www.ebay.com/itm/314691372450?var=613215009553You have a link to the seller? Thanks!
