Backup Power
Status
Not open for further replies.
sealingandbolting
David Reeves
Concord CA
Tesla, RAV$ 4 Plug in
Either a transfer switch or breaker interlock kit is required by the NEC to make it physically impossible for you to backfeed the grid.
" Is there a reasonable and safe solution for a temp supply from the truck without having to install a Generac or other brand manual transfer switch?" Yes, extension cords from the truck to whatever you want to power. Otherwise, as the note below said, you have to have a transfer switch to isolate the battery power from the grid, otherwise the batteries will try and back feed the entire grid, which clearly will not work.
Status
