Battery Coolant Leaked while with Service Department for Repair
Jojomontag
Joseph
'22 F150 Lightning Lariat SR, 24' Mach E 4X Select SR
I had an odd charging issue, which I have seen others post about: no matter where I set the charge limit, the truck would say it had charged to 100%. But upon starting the truck, the actual percentage would drop to 89%, then 87%, and so on. When I dropped off the truck with the dealer service department on 01/27, it was immediately falling to 84%.
A few days later, 01/29, I received a notice in FordPass that charging was complete. The service tech, I assumed, was recreating the issue to see it firsthand. And, once the truck was started, it dropped to 83%.
When I didn't hear from the service advisor over the next two days, I dropped in to talk to him on 01/31. He said the technician thought I may have had a setting engaged (charge limit). I told the advisor that I was insulted. I have had the truck for two years/36K miles. I know how it works.
He then said the technician is going back-and-forth with Ford's engineering hotline and would be speaking with then in Monday, 02/03, the following week.
I again had to follow up (because these techs and advisors don't seem to believe they should keep owners updated). The advisor said the engineers determined two new battery modules and a heat shield would need to be replaced. The parts were on order.
I followed up again the next Monday, 02/10, and the advisor explained that the parts were in, but the only tech who could do the job was on bereavement because his father died. Can't understand why they only have one capable tech, but understand he needs time to grieve.
I followed up again the next Monday, 02/17 (pattern?!). The advisor asked me if I had reconditioning set. I said only when I have it plugged in at home prior to really cold days or long trips. He said that the tech came in the find battery coolant all over the shop floor. I was instructed NOT to access the truck in FordPass because it could have engaged the coolant pump. Ridiculous! If such a risk existed because they decouple a coolant tube, then any power supplied to the system should have been cut off! Come back to this later... because the advisor said the truck should be ready that Thursday.
Since I heard nothing all day Thursday, 02/20, I dropped in the check on the status. I has to speak to another advisor because mine was out of town (expected because he told me). The new advisor said it wasn't ready. He called the tech, who told him they were again going back-and-forth with Hotline to run tests. But no one told me why. The advisor said he would get me an answer the next day and call me.
I don't hear from the advisor the next day, 02/21, so before they close, I drop in again. He calls the tech, does a few uh-huhs, and hangs uo the phone. He says it's the first time he's heard of such a situation. Special camera equipment came in so that the tech can wear it Monday while the engineers tie in live to see what he sees and give him instructions.
Why?!
I pry for more information. The advisor calls the tech again and puts him on speakerphone. The tech said when the coolant leaked out, it filled the battery tray and shorted out multiple components. The engineers are walking him through tests to determine how to safely work on the battery array, if it would be safe to clean out the fluid, or if a whole whole system would need to be replaced. Why is this the first time I hear this?!?!
The advisor then asked why the coolant may have leaked. The Tech said the engineers told him that either someone with a key fob walked by or someone opened the FordPass App. Really?!
What about potential OTAs?! What about the the system engaging because of ambient temperature?!
So I return to my first point that flabbergasted me: if servicing components that have a risk of engaging due to a variety of factors, isn't it common knowledge/protocol to disconnect a power source to prevent such activation?! Especially for safety or the potential damage that could be caused?!?!
The technician, due to negligence, has seriously damaged my truck and is trying to blame someone else to cover his butt. I emailed the service manager, copying Elena Ford, Karen Jones, the owner of the dealership, and the owner's son who is over the service department. I'm waiting to hear back and, if I don't hear something by late afternoon Monday, 02/24, will drop in again.
Sounds exactly like the tech did the damage, yes.
The Weatherman
South Central KY
There is no doubt that failing to follow proper maintenance procedures was the cause of this fluid leaking issue.
Welcome to the forum!
