Bed lights didn’t work since day 1…..
HOTAS
Airbus Pilot
Nothing major. My LED bed lights haven’t worked, with the push button in the bed, since I got the truck.
The passenger side worked with the interior switch.
I prefer to do stuff myself, because I can usually do it better.
A little investigation under the left rear of the truck revealed an unplugged connector.
And 4 other harness not clipped into place.
Ford F-150 Lightning Bed lights didn’t work since day 1….. IMG_7036
After
Ford F-150 Lightning Bed lights didn’t work since day 1….. IMG_7037
Success….
Ford F-150 Lightning Bed lights didn’t work since day 1….. IMG_7040
Definitely happened on the assembly line.
Stuff happens. Anyway, this truck is awesome, fantastic to drive and otherwise perfectly fine.
You have a spray-in liner. If that was done by the dealer, or a company you hired, there's the issue. If it was done by Ford, then they have the issue. But that's the cause.
HOTAS
Airbus Pilot
That was my first thought, and why I started at the ProPower panel.
But the problem was way down below with several plugs and harnesses not installed properly on the frame/body bracket.
It’s all good now.
It’s all good now.
They remove the tailgate to spray, and that's when everything gets unplugged.
WhiteBolt
Ed
CFL
Manufacturing
After
Success….
This is why UAW get the big paychecks.
