Snakebitten
- First Name
- Bruce
- Jun 19, 2021
- Coastal Texas
- 2021 F150 Powerboost Platinum
You are actually describing the classic description of the state that OTA has left many thousands of trucks in, and as a result broke the OTA ability to go further.I also bought a 2021 Platinum in Jan 2021. Everything has worked fine on my truck except the OTA update. You took your truck to dealer to install Blue Cruise? Were you told why it wouldn’t load via OTA? Also I have had a problem getting the slide button on for the automatic updates. It takes several try’s and that’s only after using two fingers on the slide button and area to left of slide button at same time. Take several tries but eventually the slide button will stay on……..until I switch truck off and after switching it back on I find the slide button in off position. I am in my garage and my wifi is connected to truck. Also I set the date and time for updates and that goes away after switching truck off also. Didn’t know if you experienced similar issue. Also what about other routine updates? As far as I know my truck has not updated OTA anything. Never have used this type of tech before so I am kind of lost on it. Any help would be appreciated
The recent TSB for the APIM update using the various USB cables and ethernet adapter addresses exactly where your truck is stuck.
It's actually fixable with FDRS and the conventional ODB adapter, but can require considerable patience to overcome.
