shutterbug
That sounds like extra work. As others have said, set max charge to 50% and leave it plugged.Keep it at 50% and plug it in occasionally to keep the 12v topped up.
Or leave it unplugged. Makes no difference.That sounds like extra work. As others have said, set max charge to 50% and leave it plugged.
Being plugged has a minor advantage, that when you need to re-starting charging can be done from the app without having to go into the garage.Or leave it unplugged. Makes no difference.
Right! In fact, I did just that recently. I was plugged in at 50% while on a trip. On the day I returned, I set it up to 80% and it was ready to go by the time I got home.Being plugged has a minor advantage, that when you need to re-starting charging can be done from the app without having to go into the garage.
