Charge port ice build up issue
smax64
New york
09 F250 FX4
Firefighter
So temps in NY plunged about 35 degrees after some rain tonight... Tried to plug the truck in and kept getting errors.
Took a look at power station pro and all looks normal. Took out my trusty portable light and found that there was a bit of ice built up on the lower connector in the charge port, had to use little wooden sticks to chisel it out.
After that all worked like a charm
Symptoms
1. Charge errors
2. Connector would not lock in at the top
Solution
1. Look for ice or build up of dirt or other debris
2. Clear it out safely, no metal.
Permanent solution probably have a bigger angle so that water would be able to drain and not cause this issue
Hope this helps someone
ErichKeane
Erich
Gaston, Oregon
22 F150L Lariat ER, 23 Mach-E Prem/SR, 90 300zxTT
Principal Compiler Engineer
My wife's Kia has a big rubber plug for the whole set of plugs that keeps it dry/clean. Its a bit of a PITA, but at least prevents this stuff.
smax64
New york
09 F250 FX4
Firefighter
@ErichKeane , the issue is on the charge port on the truck itself not not the cable side
ErichKeane
Erich
Gaston, Oregon
I'm aware. The Kia has a rubber plug that seals the charge port and keeps water/etc out of the port.
Similar to our bottom port, but a snugger/more water proof fit, and covers the top as well.
