JackJohsnon
- Mar 31, 2024
- Tuscaloosa, AL
- Looking to buy Lightning
TLDR Version: Is it possible to L1/2/3 charge while also using all the 120/240v outlets on the Lightning?
Long Version: I'm debating getting a Lightning. I foresee myself regularly being in a situation where I have access to a single outlet (say a residential 120v/15a or a TT-30). But also, would like to use the 120/240 outlets to power the day's activity (say, the A/C in a travel trailer). It'd be nice to plug the lightning into whatever shore power is available, while simultaneously powering high-draw applications and topping off the battery with any extra power (or draining down the battery if load>shore power).
I know in other EVs (like Hyundai) the onboard charger is used both to charge the onboard battery and then operates in reverse to provide 120v. Meaning, the onboard 120v outlets don't function when charging. Trying to understand if the Lightning has the same limitation.
