Convert coin holder to phone mount (Lariat)
alockbox
US
Ford F-150 Lightning Lariat
Ok so here is what I did. I used a pry tool to remove the coin holder. This is standard on the base Lariat.
Ford F-150 Lightning Convert coin holder to phone mount (Lariat) 1DCC848F-0682-483F-89E0-E39AAC2FA44A
I pried first the bottom and then the top with a second tool.
Ford F-150 Lightning Convert coin holder to phone mount (Lariat) 1F791F2B-DA2B-4FF3-A7E8-951A5D517713
Interestingly, it has a harness attached to the back end. The harness has wires but the clip does not, it just dead-ends the signal. They must be using one complete harness for simplicity of production.
Ford F-150 Lightning Convert coin holder to phone mount (Lariat) 32064AFB-5D73-4A53-A316-832D33EFD751
Ford F-150 Lightning Convert coin holder to phone mount (Lariat) B9493F67-9423-497A-9AA0-0258C12A3133
Ford F-150 Lightning Convert coin holder to phone mount (Lariat) 8D1D66EA-1C17-48B7-9D06-D5A99A6DF3DF
Ford F-150 Lightning Convert coin holder to phone mount (Lariat) F4FA864F-2CB1-4305-98A9-852C7BA79A57
The coin holder is actually two pieces clipped together.
Ford F-150 Lightning Convert coin holder to phone mount (Lariat) AED742C7-000D-4944-9735-EC8BBE284C98
Ford F-150 Lightning Convert coin holder to phone mount (Lariat) 2B453051-3462-4B9D-B960-8805F0C19D22
I had an AMPS 17mm ball mount I wanted to use. I had previously paired this with a MagSafe 17mm ball joint front-end, so I wanted to recreate that setup here.
Ford F-150 Lightning Convert coin holder to phone mount (Lariat) C406DF88-CE93-4D03-A54C-F5ECE71F2E96
I took measurements and cut some matte black acrylic into two adapter plates. One is the size of the coin holder trim and the other a little larger to sit behind the opening and sandwich the dash between them. The 4 holes are standard AMPS Mount spaces. While the mount plate itself could have worked as the front-end of the sandwich, it didn’t fill the space enough for me.
Ford F-150 Lightning Convert coin holder to phone mount (Lariat) 1B59FC7F-C821-4035-8EDE-4D6283F26B5E
Here’s how it looks assembled, only the plate on the left would be behind the dash. I tightened the assembly and put a dab of super glue gel on the perimeter of each nut to lock them in place on the rear plate. Once dry, I disassembled and then got to work installing it. I ended up drilling a 1/2” hole in the center of the rear plate to allow my finger to hold the plate as I pushed it into the dash then pressed it forward. I also applied some double sided foam tape to help hold it in place and minimize squeaks. It still took some time as I used shorter bolts, but it was doable.​
Ford F-150 Lightning Convert coin holder to phone mount (Lariat) E40640F9-B33B-48EB-9846-77DBB791FB95
The hardest part is aligning the rear plate before sticking it, so the front plate holes line up.​
Ford F-150 Lightning Convert coin holder to phone mount (Lariat) 2A70458D-73D6-454C-A413-69C8D8EE2A55
An easier way would have been to have the bolts come from the rear, glued in place, cut the right length, and used a capped nut. I just didn’t have any.​
Finished product.​
Ford F-150 Lightning Convert coin holder to phone mount (Lariat) 592641DD-96F1-474A-8CFA-B0569BC3E4A6
Ford F-150 Lightning Convert coin holder to phone mount (Lariat) 2FF71DC2-EA6B-4EC2-AFEA-5273D9AD8EEE
Ford F-150 Lightning Convert coin holder to phone mount (Lariat) 1ED19545-125F-456A-9E20-5CA6448ABE58
queuewho
queuewho
Western PA
22 F150 Lightning Lariat SR
First off, that was one super great post right there. Thanks for showing us how to remove it, and I really like your end result.
As for the harness... The integrated trailer brake controller is in that spot for premium models. I assume it would do nothing if you found that part and installed it. I wish shorting one of those leads would bring up the backup camera though.
alockbox
US
Find
Thanks! I tried to be detailed. Yes, definitely where the trailer brake controller is, I had figured the same, it would do nothing without reprogramming and having other required hardware. Shorting it and having a button for camera is an interesting idea.
queuewho
queuewho
Western PA
I mean, totally dreaming on that. Just was a thought, do Pro's have a dedicated camera button? Maybe there is a wire harness that would be able to be tapped for it.
alockbox
US
I don’t know. I specifically included a close up of the harness and colors so that someone who knows better could run through the wiring diagrams and make use of it all!
EdwinT
NJ
My pro has a dedicated backup camera button above the infotainment screen
Jim Lewis
San Antonio, TX
I got the ProClip USA Ford Angled Dash Mount (for Lariat and Platinum editions with BlueCruise cameras) that clips into the dash and passenger side AC vent just to the right of the Sync4A screen. No tools are needed (I didn't pull the adhesive strip off the top of the clip that would glue it into the lower part of the air vent).
Ford Angled Dash Mount | ProClip USA
Ford F-150 Lightning Convert coin holder to phone mount (Lariat) 1691238960404
I already owned the ProClip iPhone Adjustable Holder for Rugged Cases, so I screwed that holder base into the clipped-on phone mount, and I was good to go. Since I use CarPlay and Waze to navigate, I didn't need my phone to be that close to me. Having it mounted in the AC vent stream keeps my phone cool. It was getting pretty warm in Texas summer sun and heat sitting in any bay in the center console area.
The mount that I got has been issued by ProClip in just the last few months.
EdwinT
NJ
