default setting charge when plugged in can i change
real mccoy
ontario canada
2021 explorer. 1948 ford truck. 2006 lincoln mark
i would like to use preferred charge times but seems to go to plugged in charge as default .seems I have to change to preferred charge times every time i want to charge to my set time schedule .I cant find setting in truck it is in ford pass though. does any one know if charge when plugged in is a actual default setting. also like to know if in preferred charge times it seems to go past shut off time. i think i would not care so much if it didnt reach the charge target but stop charging in my preferred time so does per cent of charge that is set override time so charger keeps charging past set preference time.
The “Charging” app in the truck is accessed from the Home screen if you have the new interface.
real mccoy
ontario canada
i think found my issue i had weekday time set but not weekends preferred time setting. thanks i had to go to charge locations in home screen like you said
