Does Apple Maps Factor in Towing?
Deleted member 19104
Guest
Does anyone know if the Apple Maps EV integration accounts for towing? I didn’t think it did until I saw a pop up from the Apple UI suggesting that “…towing may impact range.” I know that it pulls data from the truck so if you setup and select a trailer in the Ford OS, will Apple Maps factor that into its calculations and plan?
Maximum Effort
Wade
New York
2024Lightning Flash, 2023 Mach-E
Self employed
It has not worked for me on my 2022 or my new 2024. Seems like all it does is tell you “towing may impact range. The ford navigation has been very accurate with towing if you can stand using it. As said above, the ABRP does a great jobs of calculating but wasn’t the easiest to use.
