Driver Door Seal Headliner Popping Noise
CaseyCo
Casey
Denver, CO
2023 Ford F-150 Lightning Lariat
Does anyone else have a constant popping noise above your left shoulder while going over bumps? I've had this issue on my brand new 23 Lariat since day 1. It seems like it's almost coming from the headliner where it touches the door seal or the top edge of the B- Pillar. I can't seem to put my hand anywhere to replicate it or keep it from happening. I'm 99% certain that the dealer will say that they can't replicate it or fix it. Has anyone found a solution? TIA
Dan C
I had a noise like that and reached over my shoulder and pushed on the door weatherstrip and it went away. Hasn't come back.
Ford Motor Company
Official Ford Account
F-150 Lightning
Hi there! If you send over a DM with your VIN and Ford dealer info, I can look into your concerns on my end.
BradMcD
Brad
F-150 Lightning
Having a similar problem. Most likely a door alignment issue. Push the top right of the door from the outside and see if you can hear the noise. If so, door needs to be re-aligned. Had mine adjusted and now I only hear it when hitting large bumps. Going to get it adjusted a bit more next week.
