Weather Stripping/Seal Noise
Shawnson
Edmonton
Developer
Mine does this as well. If I adjust the window a few times I can get it to go away until I open the window again. At which point I rinse and repeat. It’s annoying, but not nearly as annoying as dropping it off at the dealer and being told they didn’t hear it. ?
A dealer, not being able to replicate the issue, preposterous. Haha. I just do what Tesla wants now. Take a video of any issue I have and then show the service tech. I might not be able to submit it on the app and be all fancy, but still works. That way at least they can’t tell me I’m imagining things again. (I’ll wait for my future psychiatrist to tell me that?)
derelict
XLT ER
Just to add to this thread, I asked my dealer to check this same issue (driver side wind noise) while they were fixing my DCFC issue (in the issues thread). The notes from the tech say "no abnormal noise found" so basically they didn't do anything. I wasn't expecting them to, but I was hoping. It was very obvious to me from the day I got the truck, Its like you can hear a car driving up to pass you on the left side before they get to you. I guess I can consider it a second BLIS? LOL.
lukeryan12
Luke
Kansas City
2023 Ford Lightning Lariat
I actually did bring my truck into my dealer Olathe Ford to diagnose this issue. They had a technician drive it and they did confirm the issue is there.
Unfortunately they told me Ford hasn’t released any fix or recall for this issue. they aren’t able to start tearing apart the door to try and pinpoint the fix. He told me my seal was better than most. The service manager did confirm this is a wide issue amount f150 and lightnings.
I’ve reached out to the Ford BEV team about the issue. I guess they will be my last hope. Such a bummer for a dealer to confirm an issue on a near brand new $75k truck and they can’t do anything about it.
mdlightningIL
Martin
2024 Ford F-150 Lightning
Insurance
Morning Lightning Fam,
Was glad to run across this thread and see this is a common issue. It’s not obviously, but feel better knowing it’s not just mine. Where can you order a new door seal?
I read another thread that discusses loosening the bracket bolt that attaches the door to the bracket. This bolt allows you to adjust the door inward, thus moving the door closer to the truck body and creating a tighter seal. Did this with mine and sure enough it worked. Very easy to do and shocked dealerships are not doing this. It takes about 10-15 minutes to do and can eliminate both wind noise and a door vibration against the door seal.
It’s a shame the manufacturing process does not do a better job of taking care of this before sending the trucks out.
At the end of the day, these are pretty great trucks. I’ve driven EVs since 2016 and really like what Ford has done with the Lightning.
MJDore
SE Michigan
2023 Lightning Lariat ER
Finance
Is there a guide out there somewhere you can point us to? Or at least some pics? Thanks!
MJDore
SE Michigan
Finance
mdlightningIL
Martin
Insurance
Firn
23 Pro ER
@Firn
Can’t remember if you had this happen or who it was. Adjusted both bolts and have the door sealed up good. Somewhere in the adjustment of the two bolts, the door now sits a hair lower. So looking to keep the side to side angle as is but nudge the door back to the original height. I’m thinking I’ll have to loosen both bolts at the same time and nudge the door upward?
Not me who had the issue but sounds like you are on the right track.
I might support the far end of the door with a jack and give it just a slight bump up in height before you tighten the bolts.
mdlightningIL
Martin
Insurance
Ok, lifted the door and tightened the bolt. Closed the door, took a drive, all good. Now, that lower bracket has a little popping sound about halfway through the door motion. Haha did I lift it too much? Tempted to just use it and let the door settle naturally. Getting the door movement and wind noise resolved is awesome.
Daveo
San Diego, CA
2023 F150 Lightning Lariet ER
Finally got tired of listening to the buzzing and was pretty certain the dealer wouldn’t fix it. I was able to get the noise to stop if I pushed out on the window or made tiny adjustments to the position of the window. This pointed me to the window seal in the door frame, so I ordered a new seal.
Yes, this should have been covered by the warranty, but after several “our technician was not able to reproduce the sound” I figured it was time to do Ford’s job for them.
While not difficult, it is pretty involved to replace. You have to remove the door panel to get to a few screws that hold the front of the seal in place. Removing the door speaker is needed to see what you’re doing and align the window seal to the screw holes. There are also a lot of little wiring connectors to disconnect. Took a little over an hour and some of that was just figuring out where all the screw access holes for the door panel are. Youtube helped.
That was definitely it. Flapping/buzzing sound is gone. I looked over the old seal and couldn’t find any flaws. It looked identical to the new one. Maybe I could have just taken out the old one and reinstalled it, but at this point I just wanted the problem fixed.
I ordered the seal from FordPartsGiant.com. For the drivers side front door this is the part and not so obvious description:
Part No.: ML3Z-1521597-A
RUN - DOOR GLASS
$70 shipped.
FlatcoatFarm
Clark
Santa Cruz
You should invoice Ford for parts and your labor! ;-)
