Please don’t switch your headlights, high beams, and fog lights to LED bulbs if you have a halogen truck.
High beams are an easy upgrade from 9005 bulbs to 9011 HIR bulbs. 9011 bulbs have roughly 2x the output of 9005 and are basically the same wattage/heat output
Lows are h11 bulbs. The easiest performance upgrade are the GE Nighthawk Platinum h11’s ($25 on Amazon) but with a little trimming to the bulb H9’s (Phillips standard h9, $8-10 each usually on Amazon) will fit.
Testing from TacomaWorld forum, the 3rd gen Tacoma used a H11 low beam too and both these options have 2x the output of stock type long life bulbs.
