F150 2021 + Light Bulbs
F1502022L
Scott
GA
2022 F150 L
Trucks
Does anyone have the light chart bulb for the 2021 + F150's ? Looking to start switching everything to Led.
Thanks
Graygoose2021
Central US!
2021 F150
Sales
check out F150leds.com
skierd
Fairbanks, AK
21 XL
Please don’t switch your headlights, high beams, and fog lights to LED bulbs if you have a halogen truck.
High beams are an easy upgrade from 9005 bulbs to 9011 HIR bulbs. 9011 bulbs have roughly 2x the output of 9005 and are basically the same wattage/heat output
Lows are h11 bulbs. The easiest performance upgrade are the GE Nighthawk Platinum h11’s ($25 on Amazon) but with a little trimming to the bulb H9’s (Phillips standard h9, $8-10 each usually on Amazon) will fit.
Testing from TacomaWorld forum, the 3rd gen Tacoma used a H11 low beam too and both these options have 2x the output of stock type long life bulbs.
https://www.tacomaworld.com/threads/3rd-gen-hid-vs-led-vs-halogen-h11-projector-headlights.589465/
https://www.tacomaworld.com/threads/why-leds-should-not-be-run-in-halogen-reflectors.454371/
