Final Steps to Bluecruise email
JDinNFLA
Joel
Jacksonville
2021 F150 Platinum Star White 3.5 EB
I've seen other people mention seeing software update versions in their Fordpass app. I have both a F-150 PB and a Mach-E and cannot find software versions anywhere in the app for either of my vehicles.
Can you tell me where to look for this info?
Thanks,
Upper right corner of Ford Pass app. Click Account then scroll down To click message center. Should list all there for each of your vehicles. Unless you deleted them. Mine shows every one.
Mike G
N. AL, USA
I just received this email, with instructions to change the OTA update times. Anyone else go through this and have Bluecruise installed this way? I'm looking forward to getting it rolling.
Can you share what the recommended OTA update times were that were requested?
I don't seem to be getting updates and it may be that I need to modify the schedule I have currently setup.
Thanks,
Mike G
N. AL, USA
Yeah, must be my tinfoil hat...I had sharing info with Ford turned off so I think that's why I'm not seeing any of the updates on either my F-150 or Mach-E in the messages section. I turned it back on in the truck but I'll have to go find that setting in the car and sort that out. Both were purchased with the BC hardware, but neither of them are remotely close to the software versions required. And they don't seem to be getting any closer. My truck is on 2.1.1 and I don't even know what the Mach-E is cause I can't tell.
gtotco
Colorado
2021 F-150 Lariat 502A FX4 3.5L
I don't seem to be getting updates and it may be that I need to modify the schedule I havfe currently setup.
Thanks,
You should be able to check and update manually. I would try that to see if they are available.
tcp
Trieu
Kansas City,MO
2021 F150 Platinum, 2019 Accord
IT MGR
So is everyone that are getting these updates recently in the Early (LATE) Access Program? I've been stuck on 2.3.0 since end of January! Anyone else in same boat?
Caneman88
Ron
San Antonio TX
2021 Powerboost F150 Platinum ,2009 370Z
Pella Windows and Doors
Yes I have got 2 in 2 days but still waiting
tcp
Trieu
Kansas City,MO
IT MGR
I guess I'll stop doing hard resets on my SYNC4 10 times a day now.
Why are they still calling it early access when JOB2 trucks were the early access....
Caneman88
Ron
San Antonio TX
No clue what they are doing information from Ford to keep us updated would be great.
But then would could not complain about it on this forum o_O
Caneman88
Ron
San Antonio TX
Ford Pass shows 3 of 3 complete but Im guessing there are another group of updates for BC :rolleyes:
it
Ford F-150 Lightning Final Steps to Bluecruise email IMG_1449
Orlando150
Orlando, FL
Ford
2.3.0 is the most up to date version for those who are not one of the about 500 early access people selected to receive the test updates. Once Ford is satisfied with the rollout to the EA testers the updates will be pushed to everyone.
it
Yes this is part of the prep for BlueCruise. 2.5.3 will be the final update.
Mike G
N. AL, USA
Yeah, I do that nearly every time I get into the truck or car. It always says I'm up to date, which I'm pretty sure is complete BS. I've never ever, with any of the many F-150s I've had, ever had any of them show that an update was available when I checked manually. And my Mach-E has never told me anything but "You're up to date". But the service tech always tells me there's a pant-load of updates that need to be applied when I show up at the dealer.
So when you mentioned something about Ford suggesting or asking you to adjust your OTA update schedule, naturally I thought that it might give me a clue as to the best time to set for updates, with the hope that it would increase my chances.
JDinNFLA
Joel
Jacksonville
it
My Ford pass never showed anything like this. I’m in EA. Got email last Friday. Updates Mon Tuesday Wednesday to 2.4.5. Nothing since. What a cluster.
