Ford station pro intermittently stops charging
chickenlives
CA
F150
I charge at home using my Ford station pro charger. I have a charging schedule setup to charge at midnight. It works reliably. But if I select the option on the Ford app to "Charge to 100% now" it stops charging within 5-15 minutes and goes back to the schedule. This happens consistently. Why does this happen?
Can't explain why, Ford connected tech is very much still in beta. I find it more reliable to change the schedule when I need 100% or change to "charge when plugged in" and then change back to normal schedule afterwards.
Labs4Lightning
C
@chickenlives
how long have you had CSP?
mine started acting up(charge faults not related to heat)
power cycled unit and has been fine since.
