FordPass not allowing Pixel 8 Pro as Key
kls629
Kevin
Anaheim
Just received my new Pixel 8 Pro and can't set up phone as key. Says limited support for this phone, and error during setup.
Anyone else have this issue or resolution? Used Pixel 6 Pro as key and works correctly before.
Warp Asylum
Austin, TX
2022 F-150 Lightning Lariat ER, 2023 Mach-E GTPE
I also just got a Pixel 8 Pro but haven't tried setting it up yet. I'm not surprised there are issues though, the Pixel 7 series had similar problems initially. I think there were both FordPass and Android updates needed to get it working.
Warp Asylum
Austin, TX
I went through PAAK setup with the Pixel 8 Pro tonight on both the Lightning and Mach-E. I got the same message about limited device support, but then had no problems getting it set up on both vehicles. I put the fobs away and tested PAAK and had no problems unlocking/opening doors, and starting the vehicles. So the Pixel 8 Pro seems to be fine despite the warning message at the beginning.
One thing I made sure to do before starting was to delete the existing PAAK settings in Fordpass for my old device. Other than that, I would try the usual troubleshooting steps for Android apps (delete cache, etc). If that doesn't work you can reset all PAAK settings under general -> reset on the Sync screen in vehicle. That will delete all keys so if there are any other PAAK besides yours, those will also have to be set up again.
kls629
Kevin
Anaheim
I finally got it to work
I removed old phone by resetting on sync, then cleared cache and storage. Still didn't work until I uninstalled app and reinstalled
bg226
Bryan
Anaheim
I believe I had the same message with my Samsung Galaxy S23, but it works just fine with PAAK.
