Frunk closed but truck says its open
emmelj
Jerry
DFW
2022 Lightning, 2018 Tesla M3
Got in the truck this morning. Said frunk was open. It was not, so I opened and closed it numerous times. Rebooted. Turned truck off and on. Truck still thinks its open. Any pointers? @Ford Motor Company
Heliian
Did you try the opening height setting procedure?
Texas Dan
Daniel
'04 Envoy XL 4WD, '15 Fusion Energi, '19 Niro EV
I had a similar problem. I closed the electrical outlet cover in the frunk and that appears to corrected the problem. Not sure closing the electrical outlet cover will correct your problem.
I have not. Is that in the manual?
It is. In the online manual use the search function for "frunk".
In my manual, it's under Luggage Compartment > Opening the Frunk > Setting the Frunk Opening Height
River Rat
Magnetewan River near Georgian Bay Ontario, Canada
2022 Mach E Ice Blue, 2023 Lightning Star White
I had a problem with mine but it was because I put it in drive while closing. Somehow I popped the frunck manually and lifted it to max height, pushed the button and it closed and reset. Damn annoying you cant override the beeping.
emmelj
Jerry
DFW
well....tried about everything. The consistent chiming makes it un-drivable. Going to the shop...in 2 1/2 weeks! what bs @Ford Motor Company
emmelj
Jerry
DFW
Well.....parking outside sucks. It was a rodent that chewed a wire connected to the frunk latch.
skytrash00
Paul
Portland OR
Ford Lightning 2023
That happened to mine, it was the frunk latch. I'm sorry, and I think that it is so difficult.
