TNVolFan
RG
Kentucky
2023 F150 Lightning XLT Stanard Range
Do these work with heated seats?
Evlar77
Evlar77
Evan
Port St. Lucie, FL
2024 Ford Lightning Flash
They seem to. My wife used it on a trip this weekend and said they warmed the seat just fine. Probably takes a little longer to warm due to the added material.
Grumpy2
Central Oregon Coast
23 F150 Pro SR
Retired Hvy Construction
There was a pretty serious smoky fire last winter posted here involving seat covers in the back that had been left on for sustained time. The seat covers were used to protect the seats from dogs, so it was probably pretty thick. The point , these seats can get very hot, so you want covers that will not restrict the air too much.
https://www.f150lightningforum.com/...-fire-not-an-ev-fire.18385/page-4#post-369794
The manual includes the following:
HEATED SEAT PRECAUTIONS WARNING: Use caution when using the heated seat if you are unable to feel pain to your skin because of advanced age, chronic illness, diabetes, spinal cord injury, medication, alcohol use, exhaustion or other physical conditions. The heated seat could cause burns even at low temperatures, especially if used for long periods of time. Failure to follow this instruction could result in personal injury. WARNING: Do not poke sharp objects into the seat cushion or seat backrest. This could damage the heated seat element and cause it to overheat. Failure to follow this instruction could result in personal injury. WARNING: Do not place anything on the seat that blocks the heat, for example a seat cover or a cushion. This could cause the seat to overheat. Failure to follow this instruction could result in personal injury.
flyct
Jerry
South Florida
'24 F-450 Platinum & '23 Ford Lightning Lariat & 2 Tesla Model Ys
Blissfully Retired
I had an issue with dog cover on the rear seat. The dogs hit the seat heater button and turned the heater on. The seat got Really Really scary hot. To eliminate an issue I removed fuse #48 in the picture attached to prevent inadvertent actuation of rear seat heaters.
Ford F-150 Lightning Great Seat Cover Option with Pics! IMG_2023
Pod
2023 AMB Lightning XLT SR
All right dude, pulled the trigger. Excited to get these
Pod
Got em. Install pretty simple. Drivers seat cover moves around a bit too much. Trying to figure out a way to keep it better in place. They really do look pretty good, have to admit.
Evlar77
Evlar77
Evan
Port St. Lucie, FL
Once I got the Pucks secured behind the seat and the front clips in place mine doesn't move at all. But I do have these over the cloth seats so they grip the original seats better.
A few weeks in and they still look and feel great! Glad you like them!
