ENG430
Ahmad
Kuwait
2021 F150 Lariat 502A
Is changing tire circumstances will change and recalibrate the transmission to the new tire size.
One of my friend said that I should reprogram the gear transmission if I change to bigger tire size or it will damge the gear box.
UGADawg96
JAX, FL
302A 157 PB
I upgraded from 275/60r20 to 285/60r20 and the speedo is more accurate now. It was off from the factory.
ENG430
Ahmad
Kuwait
Any help please?
Should I change the gear ratio when upgrading to big tires?
additionsola
Utah
Chevy Colorado
Any help please?
It all depends on tire size and what your gear ratios are now... going up a few sizes isn't going to hurt anything. Hell going to 35s won't hurt anything, but you're going to kill your torque/low-end power. On my Chevy I went to 35s (from 31s) and definitely benefited from re-gearing. On the Ford, I opted for the 3.55 gears, I went to 33s and won't touch the gears.
ENG430
Ahmad
Kuwait
The tires installed now in my F150 from Ford is: Pirelli 275/60/20 .
Im going to install: BF 285/55/20 .
is it safe to keep the same gear ratio that comes from the manufacture or should change it?
additionsola
Utah
Chevy Colorado
You're actually going down in tire size....
Ford F-150 Lightning How to use FORScan to recalibrate speedometer for bigger tires 1640383579283
You'd be A-OK keeping stock gears.
Eric12775
Eric
Clinton Twp, MI
2021 RCSB 2x4 5.0 on order
Truck driver
What about when changing axle gearing? I’m planning on installing a 3.73 posi in my rear and I’m probably going to go up from 17s to 22s.
itsdchz
Lee
Clovis CA
2021 F150 Powerboost FX4 XLT with Stuff
You'll be able to calibrate your speedometer with the free FORscan software, a portable Windows device, and an appropriate ODB II adapter. The best adapter to get is the ODBLink EX for about $50 on Amazon. Stay away from the chinesium ones.
I have instructions for doing this here: https://www.mustang6g.com/forums/th...ometer-error-no-flash-or-tune-required.67564/
Pay close attention to the need to do a PCM and TCM relearn in order to clear DTC's.
Also, for the 2021+ F150 the address location has changed. Instead of:
726-12-01 xxxx ABCD xxxx
It is now split between two lines:
726-15-01 xxxx xxxx ABxx
726-15-02 CDxx xxx xxxx
The same values from my calculator linked in the Mustang 6G thread will work in the new location.
Help??
I have gone from 265/60/20 stock Hankook to 275/60/20 more aggressive Cooper Discoverer ATS. When pulling up my info in a 2021 Powerboost, under BdyCM, I look at the appropriate fields but they do not match:
Stated info from OP: 726-15-01 xxxx xxxx ABxx - This field already contains the correct value in my vehicle: xxxx xxxx 09xx (based on code gen, both sizes have this same value present)
Stated info from OP: 726-15-02 CDxx xxx xxxx - This field only has the parameters in 2 segments, ie: F3xx xxxx
Based on my stock configuration, I should have 726-15-01 as: xxxx xxxx 09xx - this is the same for new parameters as that value did not change - OK
What would I change for 726-15-02? My stock parameters are: F3XX xxxx (no 3rd segment) (the stock parameters in the HEX generator suggests that based on 265/60/20, I should be CD- CDxx xxxx xxxx, even though F3 is present on as built parameter)
The Hex generator states I should have F2 as the new value, however when I replace the F3 to the new F2 value, it states that my checksum is wrong, so I did not write The code and perform the DTC check.
Any ideas if the Powerboost BdyCM and 726-15-02 is different on 2021+ and should only contain 2 segments, not 3, and if I write the F2 value vs F3, if this is truly for the tire size?
Thanks in advance.
In summary:
As built on 2021 PowerBoost - came with 265/60/20 Hankooks- Added 275/60/20 Cooper
I have stock configuration:
726-15-01: xxxx xxxx 09xx
726-15-02: F3xx xxxx
Hex builder states I should have stock configuration as:
726-15-02: CDxx xxxx xxxx
Hex builder with new tires:
726-15-02: F2xx xxxx
Forscan v2.3.46
