Lightning v. Mach-E: Same Miles/kWH??
ridgebackpilot
Michael
Monterey Peninsula, California
2022 Lightning Lariat ER, 2022 Mustang Mach-E GTPE
Conservationist
Friends: Having both a 2022 Lightning Lariat ER and a 2022 Mustang Mach-E GTPE, I've noticed they get roughly the same miles per kWH on long freeway trips, around 2.2 M/kWH. How could that be?
If M/kWH is the equivalent of MPG in ICE cars, then the truck should get far lower M/kWH than the smaller and lighter SUV, right?
Sure, the battery pack in the Lightning is larger (131 kWH) than the Mustang Mach-E (91 kWH). But isn't that just the equivalent of a bigger gas tank on an ICE truck than an SUV?
Since the electric motors in the Lightning are bigger (350 kW) than the Mach-E (200 kW), I'd expect them to use more electrical energy, just like the ICE F-150 has a bigger engine and uses more gas than my son's Ford Edge SUV.
So why am I getting the same M/kWH in both vehicles?? What am I missing here? Perhaps M/kWH isn't the equivalent of MPG in ICE vehicles?
Reactions: s_c
You are missing nothing. The Lighting is approximately 40% less efficient.
What you state is not possible unless:
- You're driving much, much faster in the Mach-E.
- You're comparing Mach-E in dead of winter to Lightning in summer.
- You're relying on the Mach-E's "this trip" data...
- Your Mach-E has a problem and needs work done.
Blainestang
FL
F56, R55, Pro
You're right about mpg vs mi/kWh. The Mach E *should* get better efficiency in general, but the GTPE does have higher performance tires and such that hurt efficiency. Still should be better, though, according to EPA:
Mach E GTPE: 41 kWh/100 miles = 2.43 mi/kWh
Lightning ER: 48 kWh/100 miles = 2.08 mi/kWh
On top of that, the gap should get bigger on the highway (and EPA's city/highway mpge numbers agree).
These numbers include charging losses, so in-car results should be better, but yeah, looks like the Mach E is underperforming for some reason to only match the Lightning on the highway.
ridgebackpilot
ridgebackpilot
Michael
Conservationist
Blainestang
FL
F56, R55, Pro
But isn't that far less difference than an ICE F-150 v. an ICE SUV like my son's Ford Edge?
2.43mi/kWh is only ~16% better than 2.08mi/kWh, but surprisingly, a "normal" F-150 is 19-20mpg combined vs an Edge at ~23mpg, which is a similar ~15%.
I would have expected a bigger gap, for sure. That probably comes down to the Edge being pretty inefficient for it's size. 23mpg combined for a midsize gas crossover seems pretty bad.
voxel
Nelson
Altamonte Springs, FL
Mach-E 4X, Heritage Bronco, 23' GC Limited
The Mach-E GTPE is insanely inefficient. One of the worst of the EVs I've owned and I've owned too many lol. I barely achieved 2.5 mi/kWh in daily commuting (80% going 60-65mph) in the GTPE whereas with the Mach-E Premium AWD ER I'd achieve 3.3 mi/kWh easily.
It's the performance tires and overpowered permanent magnet motors.
MachLightning
Eric
2023 Mach E GT, 2022 F-150 Lightning Platinum
I have a '23 Mach E GT, and just bought a '22 Lightning Platinum. My Mach E gets about 50% more range in similar conditions on the highway.
I'm with the rest, either there's something wrong with your Mach E, or you're not using the same base conditions for both vehicles.
22legit2quit
2024 Ford Lightning Flash ER
If you’ve noticed most of the electric only vehicles, so no erevs or plugins, have very similar ranges. The lightning, model 3 or any Tesla has that 300 mile-ish range. That’s much more interesting and also much more consortium-like of the auto industry.
Yeah, I know the same range vs efficiency isn’t the same. Well aware. But outside some of the lucid stuff and the ridiculously huge batteries on the gm products, the range and efficiencies are similar when comparing each ev to one of similar size. Someone already did the math that the efficiency wasn’t that far off from the mme and lightning, which I would expect. Even with the weight difference being there but being 1800lbs heavier than the 4500-5000lb mme, the lightning is around the same amount heavier as it would indicate the difference in efficiency would be. Actually it’s probably heavier than would compensate for the efficiency gap.
The massive failure of the Mme, in how ford supported it. (I get it if you like it, they’re just way too expensive for what they are and the dealers are psychos thinking that they’ll do anything but gather dust.) but the failure is well documented. The lightning was under marketed and really overshadowed by the failure of the Mme.
My '22 Lightning PRO SR, with a ~100kwh battery pack, gets the exact same range as
my wife's newer '24 KIA EV9 Light SR, with a ~75kwh battery pack...
even though the car certainly gets better 'gas mileage', although it has a SMALLER 'gas tank'...
240 miles range, on average...
-2.4mi/kwh for the Lightning PRO SR
-3.2mi/kwh for the EV9 Light SR
one thing of note: it's generally very EASY to quickly compute actual RANGE in the Lightning PRO SR, with the ~100kwh battery pack: you just look at the Battery pack SOC %, and multiply by the mi/kwh you expect for the rest of the trip...
but, I can easily get confused in the EV9 SR, since it's battery pack is only 75kwh, therefore every % of Battery pack power is only 75% of each kwh of power... essentially every calculation is 75% of the same for the LIGHTNING. A little harder to easily compute in your brain, quickly.
