Lightning Won’t Accept More Than 46A From Grizzl-E Ultimate 80A Charger
Jay3562
Freddie
Ford 2024 Lighting
Financial Management Analyst
The 2024 Lightning cannot charge at 80 amps due to lack of dual onboard chargers. HOWEVER, 48 amp should be doable. How does your Grizzl-E show 46 amps if you dont mind me asking? I know my tesla wall charger outputs 240V 48amps to my lightning aka ~11.5Kw/hr, but Fordpass shows 10.6ish from what I assume as charging loss. I was wondering if you were going off based on that.
https://www.ford.com/support/how-to...ightning-charging-frequently-asked-questions/
"What factors should I consider when choosing a home charging solution?" section
The 2024 Ford Lighting has the fast charging port, have you tried changing the cord to a fast charging cord. I bet that would work, but at that point you might as well buy their charger.
As explained above, it's due to the limit of the On-Board charger in the truck. Nothing to do with the cord.
You also posted very incorrect information here and here. You have been very active today!
I highly suggest you watch some videos
