There is only one Final assembly line for the Lightning. The bodies and beds are assembled and painted in the same buildings as the Dearborn ICE F150.Does anyone know how many lines Ford is currently running? I’m assuming that there is still just one line, that kinda makes sense based on the numbers. 600 F150Ls per week, 120 per day and 15 per hour for a 40 hour per week production rate.
At this rate for a single line a F150L would have to come off the line every 4 minutes. That also means that a F150L could not stay at any one station more than 4 minutes unless there were multiples of individual stations like there is at the charging station.
At this rate Ford can only build about 30k F150L per year. How is Ford going to ramp up to 150K F150Ls per year by the end of 2023? There is no way that I can imagine for Ford to increase production by five times using a single line.
But how many new lines does Ford intend to build? And will they be able to add new lines in the existing building or will they need new space? Construction of these new production lines has to already be well along if they are going to make any kind of significant impact to 2023 production.
