Need a harness for adding a sub
Andrewbens
Modesto
Lightning
Mechanic
Looking for a premade harness for adding a subwoofer for my XLT truck non amplified and than if there’s any option I’m looking for a harness that could add door speakers amplifier later down the road
BlueLightning
Thomas
Oklahoma
2023 Ford F150 ⚡XLT SR
Was wondering the same here, the XLT the more you turn it up the volume the more treble it has and the bass starts to distort. So want to place a powered sub under the rear seat, but don’t know if it has easy hookup or requires too much work wiring it in.
Andrewbens
Andrewbens
Modesto
Lightning
Mechanic
BennyTheBeaver
2023 Lightning XLT ER
You'll need this and a line output converter PAC L.O.C. Pro Advanced Audio Integration T-Harness for Select 2018 to 2023 Non-Amplified Ford Vehicles, LPHFD31 https://a.co/d/elDGU3u
I also went this route this time, for some reason the accessory out isn't activating my amp. I'll have to retrace my leads and verify everything is plugged in. Did you guys add Load Resisters to the line out to the amp? If not, are you still getting systems sounds (warnings, beeps) through your stereo, or is it playing via the Instrument Panel?
I also changed all 4 speakers so I also bought the extension kit below:
https://www.crutchfield.com/p_541LPHEX17/PAC-LPHEXT17-Speaker-Harness-Extension.html
DIEProphezeiung
Charlie
Birmingham
23 Lightning XLT ER
