Power outage, no problem. Stop trying to log into my wifi 😛
Kevin
Gettysburg PA
Cadillac Escalade
Electrical Manufacturing
Nice! Do you have more details on what your generator inlet setup is like? This is the setup I’d like but I have read various things about the GFCI tripping unless you do something different with neutral/ground lines?
30 amp outlet most likely is not GFCI protected
Galactus55
Gus
Ontario - Canada
This is cool! Could you go into some more detail about your approach? The parts you used, etc?
Just to be clear the the Ford Pro 80 amp station is stand alone. It just charges the truck.
The Reliance Controls 30 Amp 7500W 10-Circuit Indoor Transfer Switch Kit comes with all the parts you need and instructions to install. Down load the manual from their web site. You will see by working carefully it is easy to install.
