PungoteagueDave
Calling BS. This is not code. I was one of the earliest Tesla owners in 2012 (#2,609), drove all over the U.S. before Superchargers were a thing, used MANY campground 14-50 hookups, never found one that would not charge my car. I have a huge box of adapters for marinas, welders, various versions of stoves, dryers, etc., and have even bare-wired a few times. No properly wired campground has 14-50 4-prong outlets that will not provide 240. And if you understand electricity at all, the fact that both sides have 120, MEANS that 240 is there.This is not always true, as I mentioned above. Several campgrounds take a 100A single ungrounded conductor to BOTH hots in the pedestal. This is not 240V but rather only 120V. In the past year alone I've encountered this four times.
Most RVs will still work because you have 120V A-N and B-N but 0V A-B. And yes, MANY campgrounds are wired this way and you CANNOT get 240V from them!
You will get 0V if trying to charge an EV on these receptacles, because the same hot goes to A and B. I have had this happen many times to me when using campgrounds to charge during the past decade.
Would it be ideal to use 240V to feed it? Yes! But since most 50A RVs have only 120V loads, it's not necessary to provide 240Vand some campgrounds did not go that direction. 2 current carrying conductors (admittedly larger) compared to 3.
