Problem with linking Ford Pro charger to Ford Pass
FlasherZ
St. Louis Metro
The "access code" is your password. In addition, the font used isn't very good, so the letter "capital I" looks like the letter "lowercase L" looks like the numeral one. Likewise you have to be able to tell the difference between the fatter "capital O" and the numeral zero.
If you are getting the ChargePoint not found error, you need to go back and do a factory reset. But instead of linking to FordPass immediately after using the setup app like the setup app wants you to, you must wait 5 minutes.
If you mash the button too many times and get put into the 15-minute penalty box for trying too much, then the charge station will not register with Siemens' VersiCharger cloud and you'll have to do it all over again.
Storm Breaker
Norm
F-150 Lightning Lariat
truck driver
How do you do a factory reset. While I was in setup mode my breaker tripped and ever since I can't get the wifi name of the fcsp to show up.
Puffoluffagus
Tyler
Georgia
23 Lariat ER
You have to open up the box. There's 9 screws. After, at the top, there is circuit board with a button that you press and hold for like 15-30 secs (power needs to be on). After, flip the breaker off then on and wait a 15 mins and the ssid will start broadcasting again.
EDITED by MOD
Joel
2023 Ford Lightning Lariat ER Red
You are the man! Thank you for this I was struggling
cal
Cal
Battle Ground WA
So I bought my Lightning used and the previous owner had installed the wall charger. When I picked up the truck months ago I didn’t get any passwords and the box + installation instructions were long gone. Don’t know if it was ever reset. Will I be able to use it at all without the connection to the Ford Pass app? Is there a separate app for the charger?
Take the cover off. IIRC, the password is on the label inside.
Reactions: cal
The Weatherman
Dean
South Central KY
Yes. The charger will operate without the WiFi/internet connectivity. It acts just like other ‘dumb’ chargers.
cal
Cal
Battle Ground WA
OMG THANKS SO MUCH!!! I had no idea I would even need an id. I figured I'd be able to download instructions if I decided to install it. All I got was the wall unit and a metal plate. Hopefully there is nothing else needed to install.
Again thanks!
swesson
Scott
CO
If you take off the gray cover, you should see all the information SSID, Password, Mac address, etc. Below is what mine looks like inside the cover.
Ford F-150 Lightning Problem with linking Ford Pro charger to Ford Pass 1699292371785
Reactions: cal
cal
Cal
Battle Ground WA
Thanks! Hopefully installation instructions are on line.
cal
Cal
Battle Ground WA
Damn wish I was still living in Parker! We'd have to find some Thai probably at Park Meadows!
Thanks! Go Broncos (yea still a fan!)
cal
Cal
Battle Ground WA
Wouldn’t know where I can find a Lightning shop manual would you? As if I’m actually going to do anything except read it! My wrenching days are long gone.
