Putco Luminix Ford Logo Light Up LED Emblems for 2021+ Ford F-150
4x4TruckLEDs.com
Gold Sponsor
Adam
Lindenhurst, NY
www.4x4TruckLEDs.com
Drug Dealer of the LED World
Now available and IN STOCK: https://www.4x4truckleds.com/putco-luminix-ford-logo-light-up-led-emblems-for-2021-ford-f-150/
Upgrade your Ford F-150, Ranger, or Super Duty with Putco’s LUMINIX LED Ford Emblem, a direct replacement for your existing badge available for the front and rear of your pickup! This installment in the LUMINIX line of products seamlessly replaces the OEM Ford Emblems using the original mounts. Each emblem is designed to spec on the OEM badge, so Putco takes all cameras, sensors, and spray nozzles into account. Installation is quick and easy as all wiring is Plug-and-Play, routing directly to the fuse box. The iP69K rated emblem is tough and durable, designed to withstand the elements and provide a unique standard look to your vehicle. With this LED Emblem you can set your vehicle apart from the rest in no time in safety and style!
Manufactured by Putco from Des Moines, IA
Ford F-150 Lightning Putco Luminix Ford Logo Light Up LED Emblems for 2021+ Ford F-150 1712759702635-fe
  • Officially Licensed: Product is officially Licensed by Ford Motor Company.
  • Direct Replacement for OEM Badge: Each Emblem is designed and manufactured as a direct replacement for the OEM Badge, allowing for an OE fit, install, and look. This includes space for front/rear camera and spray nozzle.
  • Plug & Play: Emblems plug directly into the vehicle’s fuse box for LED functionality.
  • High Quality Output: Our Front Emblem boasts 6500K White LED Output. Our Rear features our MEGA RED LED for crisp light and visibility.
  • Chip on Board LEDs: Chip On Board (COB) LEDs provide maximum output quality and miniaturization of output points, allowing us to mount dozens of LEDs. This creates indistinguishable output points on the badge and provides that smooth, consistent, and crisp illumination our emblem is known for.
  • Long-lasting Performance: The LUMINIX LED Ford Emblem is injection molded, providing a UV resilient and chip-resistant construct that delivers long-term functionality.
  • Unique Head-Turning Start-Up Sequence: When Emblem is activated via vehicle ignition or other means, our emblem displays a circular “start up” animation.
  • Finish: Premium Matte Black
  • Ip69K Rated: Will function in all elements; high rated for dust, moisture, steam, condensation, water ingress, etc. resistance.
  • Warranty: Backed by Putco’s Three-Year Limited Warranty.
  • Designed and Manufactured in the USA: Putco Inc. Des Moines, IA.
  • PATENT 11,371,688 B1
Ford F-150 Lightning Putco Luminix Ford Logo Light Up LED Emblems for 2021+ Ford F-150 1712759709994-hl
Ford F-150 Lightning Putco Luminix Ford Logo Light Up LED Emblems for 2021+ Ford F-150 1712759714344-u7
Ford F-150 Lightning Putco Luminix Ford Logo Light Up LED Emblems for 2021+ Ford F-150 1712759718517-y5
