Regenerative Braking at 100% Charge
vvgogh
Colorado
'23 F-150 Lightning ER
I was driving downhill at 100% charge displayed. Regenerative braking was still in effect with 1 pedal drive and displaying as 100% energy recovered on the brake coach. I think there's only 5% hidden capacity on the top-end. I have managed to get 3% back on one moderate downhill drive so far (not at a full charge). The 3% came back in maybe 10-20 minutes of that downhill. That would be 10-27 kW average charge rate from regenerative braking. I imagine there are some corner cases where that could exceed > 5% regenerative recovery already on a full charge (mountain houses, campgrounds, etc.). And, it's potentially a lot of power to handle with an already full battery. Certainly above what the car would choose to draw when topping off the battery off the charging port.
Is the vehicle using some of the hidden battery capacity to handle this case? Has anyone had regenerative braking disable itself if you manage to use too much of the hidden top-end capacity?
I've read that with a Tesla, if you are charged to "100%," regenerative breaking doesn't work and a message like "regenerative braking unavailable" appears. Some say regenerative braking is disabled when the state of charge (SOC) is over 90%.
Also, there is a battery buffer so to speak, that is, when you charge to 100% according to the indicator, you are really only at 90-95%.
These measure are there to prevent overcharging the battery.
Now, I assume Ford does the same/similar thing.
Effonefiddy Lightning
Alfred
23 F150 Lightning SR Antimatter Blue /2023 Model Y
True, the Model 3 can apply braking to make up for the loss of regen feel at higher charge limits.
