Bogeypro
Preston
Huntsville, AL
2021 F150 XLT
We have enough lights on the front already... hate all the glowing lights.
Chasinsparks
Ray
Woodbine, Maryland
2013 Sho, 2021 F150 Limited Powerboost
Retired United States Army
Maybe they could borrow some of the chips from that truck and put them on mine. :unsure:
futuretrunks
Jewelrean
OKLAHOMA
honda accord ‘18 ford bronco ‘21
manager
White seats?
ChasingCoral
Silver Spring, MD
retired oceanographer
Not impressed, front end, grill look so so. Ford is wrapping the glass house which is their headquarters to turn it into a huge outdoor screen, I assume this is where the reveal will happen.
Yup.
Regular150
Shawn
Purchasing
One of the cool things is the glossy black area and the four and emblem and the hood are all one piece. They rise up for front trunk, actually front bed, so let's call it the Fred, to access.
ChasingCoral
Silver Spring, MD
Using common BEV terminology, that's a Frunk (Front trUNK) in the US. Some call is a Froot (Front bOOT) in the UK but that term is far less universal.
LoneStar
San Diego
2019 Toyota 4Runner
Here's a hi-res image of the truck skateboard. Clearly has independent, control-arm rear setup which makes it the first (non Raptor) F-150 to have IRS, right? Those covers or canisters on the rear appear to hide traditional coil-over shock setup. Expected it to have some kind of active-control system for dealing with tow-loads and need for self-leveling, ideally with air-suspension like RAM.
That wheel & tire package has unusual proportions compared to a traditional truck setup. At least 21-22" wheels with aero-smoothing design and rather low-profile rubber. The tire width and tread are EV range optimized and almost useless for off-roading. Of course there will likely be more adventure oriented trims with different wheel/tire setups.
Also, notice in the left background the wall of electrical sockets with all the power tools and field equipment nearby. To me, that confirms the Lightning will have equal, maybe more ProPower Onboard than Powerboost hybrid. That's a strong differentiator for Ford in the marketplace.
Those rear disc brakes in the second photo seem pretty large too. Clearly will be a heavy beast.
Ford F-150 Lightning Revealed: First Look at 2022 F-150 Lightning [Updated with 4.4s 0-60mph run] F150-EV Chassis pic
Ford F-150 Lightning Revealed: First Look at 2022 F-150 Lightning [Updated with 4.4s 0-60mph run] F150-EV Chassis pic2
Foxtrot150
Houston, TX
2021 302A PB SCrew 6.5
Standard on XLT: 2.4kW Pro Power Onboard – 120V outlets: Two in the cab, two in the bed and four in the trunk
Optional on XLT, standard on Lariat/Platinum: 9.6kW Pro Power Onboard – 120V outlets: Two in the cab, two in the bed and four in the front trunk, plus a 240V outlet in the bed
Wvmtneer
Usa
F150
The raptor does not have IRS. 2021 raptor will have a solid rear axle with coil springs instead of leaf springs.
ZWARRIOR
2021 Ford F-150 Lariat 501A 2.7l
Software Engineer
The range feels way too short, it will probably give 100 miles with towing, I am mostly excited though!
ChasingCoral
Silver Spring, MD
Are these the power parameters on the Powerboost hybrid?
Vulnox
Livonia, MI
I'll be at the reveal tonight, look out for a Velocity Blue PB in the stream!
Regular150
Shawn
Purchasing
Hey CC, glad to see you too reserved the F150 to pair with your MachE! It's my own special terminology because trucks have beds not trunks. So I'm calling it the Front Bed, or Fred for fun!!!!
