Rivian R1T Towing Range Information
fitek
Peter
Washington state
Ford Transit 350EXT
There is a shallow angle ramp near me that I generally avoid for that reason. If I have to use it I found if I back until my tires touch the water it floats the transom and I can push up on the bow and get it launched. This is on my 19’ center console on a bunk trailer. If I had rollers it would slide right off. If on bunks you could also look into the slippery plastic pads for the front bunks to promote it to slide easier.
I live four blocks from this shallow boat ramp into the bay that mostly gets used by kayakers, versus the good one fifteen minutes away that always has a line. I have carpeted bunks and they're not very slippery. I'll look into pads. Boat is 12 feet long and 800 lbs so it's possible to muscle it around.
