Mr. Flibble
- First Name
- George
- Dec 15, 2021
- Seattle Suburbs
- 1995 Delica L400, Kia Soul EV, Jeep Diesel
- Occupation
- Computer Nerd
I think that is what the intent would be, and to be honest, it would be perfect for our needs. I just hope Ford decides to go through with it, because the idea is brillant.this would be an awesome solution for those that don't tow often. could be a rental from the dealer.
I don't think it will give as much range as a typical F150 Powerboost when towing, a complete random guess would be an additional 50% of range while towing. This is based off guesses around the size of the engine in the box, and if it is hooked up to the Pro Power in the bed, and it having a reverse capacity of 7.2 kW (same as output).
Some things that would change my complete wild guesses:
- Being that the engine is built to charge a battery, it could run in the ideal RPM/Power range and always remain in exactly that needed range, so it might output quite a lot more than that.
- The Pro Power Onboard could possibly accept a lot more input power than I am guessing
- The actual hookup for the range extender could have nothing at all to do with the Pro Power Onboard, and be hooked up elsewhere.
