Towing With An Electric Truck - Is It Cheaper Than Gas? Rivian R1T vs Ford F-150 PowerBoost
Formerly
NY
Ford Lightning 2022
Construction Estimation
TBH, I don't really blame them. Not that there would be a lot of competition for something that I assume would normally be rented from a dealership. I wonder if you could get more range with a perfectly tuned motor? Unlike a normal generator, which would have a range, you could tune the engine for a very narrow power/efficiency band - assuming it is worth the cost to do so.
This is how the Edison logging truck is designed.
wilmerfjohnson
Wilmer
Lehigh Valley PA
2023 XLT SR,2021 Bronco, 2018 Fusion, 2009 Mariner
To answer the original question - is it cheaper? In my use case, Y E S !!! I'm sure there are 18000 ways that this is not a 'fair' comparison, but here is what I've learned towing. Every summer I need to tow a 7000# high top enclosed utility trailer about 14 times. Drive to where the trailer is stored, tow it to various sites between 45-50 miles from where the trailer is stored, drop the trailer at the site for a week, then pick it up and return it to storage. No long-distance road trips. With the 2010 5.4L F-350, each loop burns about $60 in gasoline. The SR Lightning does the same loop using $22 worth of electricity (that is charging at home, not L3 on the road.)
So you are saying - how does he do it with an SR? I leave home at 100%. When I get to the trailer storage site, I can L2 charge while I am doing PTI on the trailer (and chatting with various people at the storage site) - this gives me about an hour on 24 amp L2. I'm not sitting around waiting for the truck to charge, I'd be there for an hour anyway so I plug in.
The economics work in favor of the EV if you can complete your tow & get back home (or to the shop) to charge.
davehu
hot springs, AR
agreed.. If you have to use DCFC's you won't be saving money on gas.
