Running board lights not working on one side only?
joer1220
Joe
West Palm Beach, Florida
2022 F-150 Lightning XLT
Lightning Designer
I noticed my passenger side running board light isn't turning on when the drivers side does. I saw a post where someone said this happened and the cable was just unplugged underneath the vehicle. As far as I can tell this is not the case for me. Has anyone experienced this? Its LED so the light can't burn out.
Lytning
Georgia
I have not experienced the issue, but LED bulbs do indeed fail. LED bulbs include sensitive electronic components subject to damage by heat, moisture and vibration. The Ford Extended Service Plan offers coverage for LED failures.
joer1220
Joe
Lightning Designer
Perhaps I should try plugging the passenger side into the drivers side to see if its the light or the supply
Lytning
Georgia
If you have a multimeter, you can check for voltage on the supply side of the connector. You should have 12 volts DC across the conductors when the driver side LED's are illuminated.
Ford Motor Company
Official Ford Account
F-150 Lightning
Good morning, Joe. If you are still experiencing this running board light concern, go ahead and privately message us with your VIN and dealer info so I can look into this on my end. Thank you.
Deleted member 20891
Guest
Hi, I also got a 2022 lightning lariat and the running board light on passenger side is so dim (almost impossible to see the lights shining) I tried to search and see if there is a replacement for the light assembly but unable to find anything (other than the replacement of entire running board) any lock who find out the replacement light fixture? Cause it seems to be replaceable without changing the entire running board
