Setting Charge End Time
Would you like Ford to update the charging program to allow us to indicate a charge end time?
  • Total voters
    39
Very helpful. Thank you. Is this the case for L2 charging a cold soaked battery as well? Or it happens only for DCFC because there is more power involved?
I don't use the data sensor tools others on the forum do to confirm the numbers, but it makes sense that level-2 energy is first being used to power the PTC and circulator pump, you can hear it when first plugging in the truck, the battery is warmed just enough to make it chemically safe to begin charging.
I observed something odd this morning, we had a mild raining night Friday into Saturday, wake up temps in the low 50's, I used the remote starter for a 15 minute cabin warming session, using 4.2 KWH, this was a bit more than I've used in the past typically 2-3 KWH.
Sorry for the O/T observations in this thread but I wanted to follow-up on my prior post, comparing it to this mornings 30 minute remote start session, I actually used less energy today while it was 20ยฐ outside, only 2.51 KWH, and the energy flow by the minute was a more typical profile today than previously, a few minutes of peak energy, then a tapering down, then cycling.
Ford F-150 Lightning Setting Charge End Time 1705330025847
Ford F-150 Lightning Setting Charge End Time 1705330044410
Ford F-150 Lightning Setting Charge End Time 1705330296058
