Knickell
Stock offset is +44
Those second gen Raptor wheels with the BGG KO2s is a pretty sharp look!
Stock offset is +44
Iām seriously considering your exact rims and tires for my chromed antimatter.... can you please post a up-the-side view so i can see how much the tires stick out with that width and -24 offset? Iād love a visual, thanks!
No problem. Iām just blacking the wheels out right now while I decide on a leveling kit. Then Iāll get another set of wheels nā tires. Just trying to do my due diligence before pulling the trigger on a setup.Thanks Nifty!!
U doing lift and new wheels and tires?
Can you post a picture after you did the black out? I am planning to do the same. THanks ahead!No problem. Iām just blacking the wheels out right now while I decide on a leveling kit. Then Iāll get another set of wheels nā tires. Just trying to do my due diligence before pulling the trigger on a setup.
Ask and you shall receive.Can you post a picture after you did the black out? I am planning to do the same. THanks ahead!
DIY or pay someone?Ask and you shall receive.
Looks Sweet, is that powder coated? Gunmetal? Satin Black?Ask and you shall receive.
Thanks NiftyF150! It is awesome. Did you pay someone doing it? Can you post the link where you buy the spray if you did it yourself?Ask and you shall receive.
Thanks for sharing your technique with excellent photos.Plastidip fellas. Did it myself. You can get it at Menards.
I like the option to peel it off to put the wheels back to stock if I decide to sell. Wheels and tools are the the only things Iāll use the stuff for, but it looks good and holds up great with good prep work.
Just make sure you pull the wheels and hand wash them, mask properly, and the lay on a lot of thin layers with minimum 30 minutes between coats and I think youāll be impressed with the results.
Worst case scenario you donāt like it... Just peel it off!![]()
