Supplies for charger install
theblunden
NC
2023 F150 Lightning XLT
Started looking into what supplies I need for my install on my home charger only to find that 60 amp GFI breakers and 6 gauge 3 wire Romex are about impossible to find. All of my local Lowe's and Home Depot are sold out within 100 miles. Found a breaker and 6/3 wire on Amazon about a week out from being delivered. Times are different right now for sure.....
merek
Buffalo, NY
F150 Lightning Lariat ER [6/20]
You might have better luck looking at a local electrical supply house, some of the bigger gauges, etc, are just not common enough for Home Depot.
PA Lightning
Tbone
PA
Lightning Pro
What charger are you installing?
It seems like the Ford Mobil Charger would take a 50A GFCI breaker (recommended), and the Ford Connected Charger would take a 60A non GFCI
Dirtyrider89
Korey
Ohio
F150
Technician for cranes
I bought 6 awg wire from menards
theblunden
theblunden
NC
Apparently the Charlotte area is EV crazy I guess. I'm wiring up a 60 amp breaker to future proof any charging setup in my garage I'll run the provided charger from the Lightning before I upgrade to see if it works for my needs
FlasherZ
St. Louis Metro
6/3 NM cable (Romex) cannot be used with a 60A breaker for a 48A EV charging load. 6/3 NM cable is only good to 55A (60A required for 48A EV charging) and so it can only be used with 44A charging load or less. You must use wire-in-conduit for #6 to feed 48A charging current or turn the charging station down to 40A charging current.
theblunden
theblunden
NC
Thanks for the heads up works out they were sold out lol
jefro
F150, Corvette, Bolt EV,
How much do you expect to consume in energy now and in the future?
I bought my evse because it had adjustable power output. I installed my evse and set it to lower power because I knew I'd never need to run it at full power. Unless someone is a contractor or drives a heck of a lot I don't see the need to over provision. The future ought to be more efficient rather than less I'd think.
