B177y
- First Name
- Bill
- Jul 16, 2024
- Oly Pen, WA
- 2024 Pro SSV ER Max Tow
I posted a much abbreviated version in the "Towing/Hauling/Trailering" section under the Data Thread sticky.
Truck:
2024 Lightning Pro ER Max Tow
Trailer:
2018 JayFlight 242BHSW, ~6500 lbs for this test
Efficiency:
Ford dash: 0.9 mi/kwh
ABRP towing profile calibrated consumption: 0.96 mi/kwh @ 65 mph.
Distance:
135 mi round trip. 67 mi to Tesla Supercharger and 67 back.
I made a towing profile on ABRP that estimated 1.15 mi/kwh, which ended up being too optimistic. I wanted to get some real world and more accurate towing stats for upcoming summer fun. My previous tow rig was a 2001 F350 V-10 gasser. This will be my first "travel trailer season" with the Lightning.
My travel trailer is 24' long (30' from hitch to rear bumper), 11' tall (with air conditioner), 8' wide. Pretty square front, not really aerodynamic. Maximum weight on the sticker is 7250 lbs with weight from factory listed as 5726 lbs. I haven't been on a scale but I estimate that I am probably around 6500 lbs for this test run.
I did a round trip from Sequim, WA to the Tesla Supercharger in Forks, WA and back to Sequim. Left my house at 80% charge since it was a spur of the moment thing. Combination of 60 mph highway and congested streets with construction through Port Angeles. Just under 140 miles total. Truck displayed outside temps mid 50's to mid 60's, sunny and no real wind.
The Lightning tows like a dream! When I got home I adjusted my WDH (an old Eaz-lift) adding one more washer of downward force on the tow arms as I felt a little light on the front wheels going over some poor sections of road. I had the Eaz-lift adjusted per the Lightning's hitch setup menu where you add your trailer details and it guides you through the sequence of hitched with no arms, then hitch with arms attached, and you adjust your WDH to get into the "green zone". Other than that, compared to my old F350 the Lightning drives MUCH nicer and the torque is supreme.
The downside is that I will need to plan for stops where I can charge with the trailer attached or have sufficient area to drop it while I charge. There is one trip that my family has taken for the past few years that is 335 mi one way that will require 4 charge stops along I-5 and I-84. Many of the fast chargers along this route are not optimized for larger towing rigs, so I'll be digging through ABRP and PlugShare to check for trailer friendly stops.
Truck:
Trailer:
Efficiency:
Distance:
