Using the 2.4kw on board generator for trailer loads.
jmonterc
Joe
Colorado
2021 F-150 Hybryid
Retired Electrical Engineer
If your planning on buying the hybrid with the 2.4 KW on board generator to power your trailer be aware, It can't handle much of a load. It will not run your AC, the load is too great. To run the AC or start a 2 HP motor you must have the 7.2kw option. I am so sad that I didn't check the specs. I would have easily been able to get the larger inverter. Now I' stuck with a truck that can't handle all my needs. :(
jmonterc
jmonterc
Joe
Colorado
2021 F-150 Hybryid
I thought that might help but if your running from the inverter I'm concerned that there may be harmonic interaction that will harm the inverter or the soft start. Any thoughts about that?
Snakebitten
Coastal Texas
2021 F150 Powerboost Platinum
I'm disappointed for you because powering an RV with the Powerboost Pro-Power is a match made in RV heaven. And for only an additional $750, it's just silly to even offer the 2.4 on the Powerboost truck.
Regardless, if I found myself in your plight, I absolutely would invest in one of the high-end softstart (you get what you pay for approach) and find out for myself. The truck is in warranty and there's nothing I see documented that would indicate you would be using it outside its intended use.
When I purchased my Powerboost, the dealership actually had 2 of them in their Covid depleted inventory. I asked them how they haven't sold immediately and they said they suspected it was because they were fully loaded Platinums? I don't know if that's the reason, but I was pleased I actually had a choice. But then I looked closer and one of them was the 2.4 KW.
Seemed even silly'r to load up a Platinum Powerboost and NOT get the 7.2KW.
Made my decision easier. Even though I didn't want a Black truck. (The other one was the dark red)
Turned out it really wasn't black afterall. (Kodiak Brown. Just pretends to be black)
Anyways, I hope you do give a softstart a chance. It'll be interesting.
