Weird noise going over uneven road or turning through bumps/drainage swaths
Ford Motor Company
Official Ford Account
F-150 Lightning
I have the same clunk from the rear passenger area. haven't been able to pin it down.
Hi there! I can look into your Lightning's noise concern on my end. To get started, could you please send a private message over with the name/location of your local Ford dealer and your Lightning's VIN?
bellyer
Chicago
2021 Mach-E FE & 2023 F-150 Lightning Lariat ER
I am also having this issue. It is definitely a clunking noise that sounds almost like a bolt came loose inside the header above the rear passenger seat. It happens most often when going over uneven terrain, but I also notice it when making some turns. It does stop sometimes and I find that I cannot reproduce it on-demand to try to pinpoint it, but it happens a lot and is super annoying.
dothedew
Colorado
This is exactly right. It might be the weather (relative heat/coolness of the cab or sorrounding pillars)? It's definitely not the seatbelt in mine as I've noticed its happening even when the seatbelt is plugged in
Ford Motor Company
F-150 Lightning
Good morning- I can look into this for you. Feel free to send over a private message with your VIN and dealership information at your earliest convenience.
Knightro2
Jay
Central FL
F150 Lightning
Was the cause ever discovered? I purchased a '23 Lightning Lariat last December and have had this exact same noise issue. I can't figure out what it is.
kstype
Kurt
Pennsylvania
Principle Systems Engineer
FYI the morning I was scheduled to go to the dealer on this... the noise was gone. I spent an hour driving around that morning over all sorts of bumps to try and trigger it.
I THINK I nailed it down to rear passenger seat belt rattling against the frame. I have been trying to reproduce it as much as possible but its very intermittent. I will circle back if I have any more success. Finally I found a useful way to apply the scientific method we all learned in grade school.
It’s funny you say that - I really do not have rattles from things like body panels - but how the front/rear seatbelts orient themselves after passengers exit can cause them to bump up against the B pillar and make noise. I find they do this when they are angled between the seat and the B pillar and find myself stretching over to push them so they lay flat between the seat and the pillar. It may help if Ford padded the B pillar up to the hang point for the buckle with fabric instead of hard plastic.
The only other noise issue I had was a clunk when speeding up or turning. It sounded like a loose ball joint or similar - but it ended up being the Frunk lower tray that covers the “ice box” section. There is about a 1/4” to 1/8”gap surrounding it…the dealer I go to isolated the issue and added some small foam bumpers to prevent the sliding and some velveted tape in the ledge where the tray sits in and this resolved the clunk issues:
Ford F-150 Lightning Weird noise going over uneven road or turning through bumps/drainage swaths IMG_0913
Ford F-150 Lightning Weird noise going over uneven road or turning through bumps/drainage swaths IMG_0912
Ford F-150 Lightning Weird noise going over uneven road or turning through bumps/drainage swaths IMG_0914
Ford F-150 Lightning Weird noise going over uneven road or turning through bumps/drainage swaths IMG_0915
TheBigBezo
Earth
It's crazy I found this thread, I just noticed a clunking sound when I would accelerate recently and I'm betting it's this! I used to have a trash bag full of recycled golf balls in the frunk and assumed it was them, but they're out now, so it had to be something else and it sure matches up.
lightspeed
2023 Lightning Lariat ER
I have the same clunk that seems to come from the back and mainly happens on bumps that twist the cab a bit. I can check the frunk cover plastic from the above post, but it really sounds like it comes from the rear.
I'm starting to think it's the rear sliding window.
I haven't been that worried about it, but it would be nice to fix it. To describe it again, it sounds kind of like a small item hitting the body in the back of a trunk of a normal car. It's not a rattle. It's not high pitched. It's a medium CLUNK type sound.
kstype
Kurt
Pennsylvania
Well I certainly hope this resolves it for you - I know it was driving me crazy…so fingers crossed!
kstype
Kurt
Pennsylvania
I was also thinking the soft fuzzy side of Velcro tape would also be a good match thinkness wise and would blend in well.
@Ford Motor Company Company - you may want to cut this issue off at the pass and add these in assembly in the future.
Knightro2
Jay
Central FL
F150 Lightning
My clunk is definitely coming from the rear passenger area. I had my 7 year old back there trying to track the sound down. He narrowed it down to that area. I don't think it is seatbelt related since I get the sound with and without someone back there. My next step is to get someone else to drive my truck around while I'm back there.
Knightro2
Jay
Central FL
F150 Lightning
Ok, not where I thought it was coming from but it is my sunroof. On a whim I tilted it (didn't open it fully to keep road noise down) and the clunk went away. I closed it and the clunk has been gone now for a bit.
Lucky Larry
Calgary, AB, Canada
23 Lightning Platinum, RX 350, Pontiac Solstice
i experienced this noise over the last month or so. its definitely caused by flex in the cab at lower speeds while going over uneven pavement and sounds like it is coming from the back of the cab. i tried several things including:
raising the lower part of the back seats
lowering the rear seat backs
checking the upright plastic trim at the back of the cab
tightening the jack tie down strap
removing the under seat bin
removing the jack
and finally tilting the sunroof up for a bit yesterday.
removing the jack reduced some of the noise and tilting the sunroof up for a few minutes seemed to be the main source of the noise.
i plan on lubricating the weatherstripping on the sunroof portion of the roof this weekend as it may be dry.
