Winter battery temperature management
Tony Burgh
Tony
Western Pennsylvania
22 Lariat ER
if you don’t want to charge to maybe 90% every night during cold winter weather, which trickle charge method would you go with: mobile charger on 110v line or FCSP set to 6 amps? In every individual’s case there are physical pros and cons but just consider the HVB.
I would leave the FCSP where it‘s normally set and set a one-time charge limit in the truck…..if you don’t want to charge at all, put the limit below current state. But I’m not sure why not just let it go to 90%???
Tony Burgh
Tony
22 Lariat ER
I would rather have the battery discharge down to 20% then charge weekly to 90%. Keeping the charge rate low should avoid having the hvb sit at 90% for days.
I don’t think that strategy provides any tangible benefit. And don’t forget, in single-digit temps, your range could be 50% of summer.
Tony Burgh
Tony
22 Lariat ER
I plugged the FCSP in to my truck at various amperages set with the charge station section of the Ford Pass app. To measure current I had to remove the bezel and front cover. While charging, I used the amperage slider to select each setting. At 80 I measured 78, at 64 I measured 64 and at 48, I got 48. So far so good. At 36 I measured varying amperages from 20 to 40. Not good. At 18 I got similar variability around 18 amp. The surprise was at 6 amps I measure 24 amps with erratic swinging measurements. I made the changes on the fly and measured with clamp meter.
I tried unplugging and re starting on the lower charge rates but that didn’t help. I stopped charging at 70%. I started around 42%.
I don’t think I’ll use the charger at low amps as a cold weather battery tender.
