XLT taillight LED bulb fitment?
TRSCobra
WA
2021 F150 XLT
Looking to upgrade my incandescent bulbs to LED but the stock bulbs are a W21/7W and I can't find much info on them. Also there's not much room behind the bulb sockets for a nice large heat sink bulb like the VLED V6 tritons.
Anyone find a bulb that works?
Ford F-150 Lightning XLT taillight LED bulb fitment? 20210422_173101
supamonks
Jon
Hamilton
2021 Ford F-150 XLT
Also interested. I just emailed F150 LEDs and they said they are currently developing new harnesses for their LeD bulbs.
Anyone have experience with the 13 gen kits?
John_C
2021 F150 XLT 302A PowerBoost
Following. I'd love LED bulbs until I retrofit the LED tails.
cghall77
Whitby, Canada
F150
Has anyone releases a led bulb yet for the tail lights?
PeteRit
Pete
21Colorado
21 Lariat PB
They are WT21 Bulbs and there's plenty of LED replacements you could use. You may need Ann online resister to combat hyperflash or flickering but it's not that odd of a bulb. Super duty guys have been dealing with these things as well for at least two years.
TRSCobra
WA
2021 F150 XLT
VLEDs told me their 4257 bulbs would fit but they were too wide for the socket. Could have filed them down but that would've voided the warranty if I had any more issues. Ended up returning them.
Ford F-150 Lightning XLT taillight LED bulb fitment? 20210807_102917
Ford F-150 Lightning XLT taillight LED bulb fitment? 20210807_102338
Ford F-150 Lightning XLT taillight LED bulb fitment? 20210807_102602
Ford F-150 Lightning XLT taillight LED bulb fitment? 20210807_102741
Mortonsk9s
Josh
Oklahoma
2021 F150, 2018 F150, 2020 Explorer
Engineering
3157 bulbs is what you need. Works perfect!
Any hyperflashing? They put everything else on LED but the rear brake lights and rear turn? I know the reverse light is led. I am curious on converting as well. What about the 3rd brake light I know the clear lights are LED but is the red portion? I have not had time to check it myself.
Thanks
Whoskyle
Kyle
AZ
2021 F-150 XLT
Thanks
Yes you get hyper flash, but disabled it with Forscan!
It amazes me why everything else is LED except these
And unsure on 3rd brake light unfortunately
Mortonsk9s
Josh
Oklahoma
Engineering
Gotcha, thanks it has been a few years since I used forscan. I still have my obd2 to usb connector. I have heard some guys say the reflective led headlights turn signal uses a standard bulb not sure either.
TRSCobra
WA
2021 F150 XLT
Forgot to update this thread. I found GTR Lighting 4257 bulbs from The Retrofit Source fit great and work well.
Ford F-150 Lightning XLT taillight LED bulb fitment? 20210902_150155
And for the hyperflash, it flashes at thw regular rate outside the truck but only the turn signal indicator inside the truck flashes quickly. If that bothers you, you can use forscan and disable "Rear Bulb Turn Outage"
Ford F-150 Lightning XLT taillight LED bulb fitment? 20210902_155951
