- Dec 22, 2019
- Purple State
- F-150
- Occupation
- Admin
Hmm this says no mechanical change but range increased by 10 miles on the SR. Anybody else think this is some sort of software update to reduce the buffer? Potentially coming to the 22 trucks as well?
Where does it say anything about Range. Numbers are TBD.Hmm this says no mechanical change but range increased by 10 miles on the SR. Anybody else think this is some sort of software update to reduce the buffer? Potentially coming to the 22 trucks as well?
Huh? Ford Press release right here https://media.ford.com/content/ford...f-150-lightning-standard-range-increased.htmlWhere does it say anything about Range. Numbers are TBD.
Ford put out a press release saying it has raised the range of SR batteries.Where does it say anything about Range. Numbers are TBD.
Unfortunately, I do not think so. I noticed that when I removed my antenna for the car wash that I did not have good FM reception until the antenna was reinstalled.Bye bye AM radio. Does this mean the big antenna is gone?
Yeah, that part is confusing to me, since the justification for the 'whip' antenna is AM radio in middle-america. I almost wonder if there was an AM-ONLY option for fleets that got removed? That perhaps just got replaced with AM/FM?How the heck do they remove AM radio only? I can’t imagine there was a chip being avoided that removes a constraint.
Yeah, just removing it makes it pretty bad, but the 'shorties' that get sold everywhere seem to do a 1/2 decent job unless you live far from reception. Mine was 'worse' (and I'm in a roughish area for FM anyway) with the shorty, but still good enough for my uses.Unfortunately, I do not think so. I noticed that when I removed my antenna for the car wash that I did not have good FM reception until the antenna was reinstalled.
The antenna delete is responsible for the 10 mile range increase in the SRBye bye AM radio. Does this mean the big antenna is gone?
The antenna delete is responsible for the 10 mile range increase in the SR.
(actually, it's from adding heated seats)
Heated seats as standard caused the change.Hmm this says no mechanical change but range increased by 10 miles on the SR. Anybody else think this is some sort of software update to reduce the buffer? Potentially coming to the 22 trucks as well?
