Aspesi4
In Massachusetts there's a rebate program for electric trucks that was recently introduced. The GVWR of the truck needs to be 8501 lbs or more to qualify for an additional $7500 incentive.
I've seen reports that the Lighting weights 6500 lbs and has either a payload of 2000 lbs or 1800 lbs depending on the battery configuration. Based on this, I'm assuming the standard range battery truck weights 6500 lbs with a 2000 lb pay load gives me a 8500 lb GVWR missing the incentive by 1 lb. Do I have this correct? For the extended range, I'm assuming it weights 6700 lbs along with the 1800 lb payload for a similar GVWR to the standard range truck. Either case, it is just shy of the 8501 lb requirement for the $7,500 rebate....
Am I missing anything? It would be sweet to receive $7500 from MA and $12,500 federal incentive (if that happens).
