Tizzzo
- First Name
- Ed
- Feb 5, 2021
- California
- 2021 Lead Foot Gray XLT 5.0 Supercrew 4x4
- Occupation
- Veteran
No I don't believe they have different struts, what's going on is that we are all using 15-20 kits on our 21s which is perfectly fine and they fit but the measurements are off now because of the change in the geometry of the new 21 model. That is why Roush advises to lower 5/8 inch on their fox coil over kits to get a true 2 inch lift. That means that setting our struts at the 2 inch setting is realistically giving us about 2 5/8 inch lift which makes perfect sense. I'm surprised nobody has mentioned this so far. I am using the bilstein 5100 leveled struts with different height settings similar to the eibach kit and I also set mine at the 2 inch setting and got about 2 1/2 ish lift after it settling. So if you want 2 inches of lift only, then I would think you can set it at the 1.5 setting but only way to find out is for someone to install it at that setting. I didn't want to pay double labor to take them out and change them again so I left mine as is as well. Loving the perfectly leveled stance though!That’s the first I’ve heard of the engine options having different struts. So if you install factory 3.5EB struts on a 5.0 you should get 3/4” of lift?
That’s really going to throw off the charts for adjustable clip style strut replacements.![]()
