NiftyF150
Yes, 2.5” level.do you have a leveling kit?
Looks good!Here is a pic of 295/70-18’s and 0 offset rims, they fit great! Only had to trim the fairing about a 1/2”. Better proportion in my opinion than the 315’s (35’s) on 17’s like the raptor has.
looks great, i love the front tow hook-to-shackle conversion!Mounted up a set of 35x12.50 Toyo Open Country AT III on the stock 18's. Very impressed with how they ride. Much better than my Nitto's ride. Of course it's a D rated tire vs's Nitto's E load.
I apologize these are not the best pics, truck is dirty.
what brand and model 2.5" ?Yes, 2.5” level.
Supreme Suspensions - Front Leveling Kit for 2004-2020 Ford F150 2003-2017 Ford Expedition and 2005-2008 Lincoln Mark LT 2.5" Front Lift Aircraft Billet Strut Spacers Kit 2WD 4WD (Black) https://www.amazon.com/dp/B00IPXL0I0/ref=cm_sw_r_cp_api_glt_fabc_2NRE618SH3NP7D1YTCW1what brand and model 2.5" ?
Looks great on the 35s! Also what tow hook shackle are you using?Mounted up a set of 35x12.50 Toyo Open Country AT III on the stock 18's. Very impressed with how they ride. Much better than my Nitto's ride. Of course it's a D rated tire vs's Nitto's E load.
@MIWheeling looks great! Is that stock suspension (no level) ?? Thanks!275/65R20 BFG KO2'S Third vehicle I've put these tires on. Love em.
Thanks! I have the Roush 2.0 coilover level lift on it.@MIWheeling looks great! Is that stock suspension (no level) ?? Thanks!
That is a known issue with KO2’s. Our shop struggles to get them balanced and has to go grab different tires until they get it figured out. They’re a good tire but we don’t recommend for that reason…pain in the ass.Though I would add my experience… I swapped my OE 275/60r20’s for BFG KO2’s in the same size (LT 275/60r20). I loved the tires but my truck vibrated in the 70mph range. I had them rebalanced 5 times and discount replaced the rear tires under warranty twice… didn’t help, Ford dealer also tired to road force them and that didn’t work. After 7 months discount replaced the KO2s with Yokohama Geolanders G015 (also LT 275/60r20) now the vibration is gone. The geolanders don’t look as good but worth it not to feel the shimmy
I ended up ordering a set of 285/70R17s for it as my tire store couldn't find the tire I wanted in the 285/75R17 size in stock. Going with the Yokohama Geolander A/T. I do a lot of highway driving in the snow and ice and know these tires are competent without being too loud. I will update here on fitment with the stock XL steel wheels and no FX4 package. The tire store doesn't think it will fit. We will see.Thank you for the feedback. I know I have seen a few owners fit the 285/75R17 on the previous generation using stock wheels without a level kit installed, so I was hopeful the newest generation would be the same. I believe the raptor wheels are a different width and offset from my steel wheels. I may just give it a go and if they fit, great, if they don't, I will install a $100 puck lift and roll with it. Not a huge deal either way. The front is super low on my truck anyways even with a loaded contractor shell on the back.
Did you ever find out out what to to shackle kit he is using?Looks great on the 35s! Also what tow hook shackle are you using?
I just got KO2's a couple of days ago and also noticed it would vibrate at 70-72mph. I used my reward points so I had the dealership insall them. I guess I'm gonna have to go back! For a minute there I was thinking it was the roads up until I read this.Though I would add my experience… I swapped my OE 275/60r20’s for BFG KO2’s in the same size (LT 275/60r20). I loved the tires but my truck vibrated in the 70mph range. I had them rebalanced 5 times and discount replaced the rear tires under warranty twice… didn’t help, Ford dealer also tired to road force them and that didn’t work. After 7 months discount replaced the KO2s with Yokohama Geolanders G015 (also LT 275/60r20) now the vibration is gone. The geolanders don’t look as good but worth it not to feel the shimmy
