- Dec 22, 2019
- Purple State
- F-150
- Occupation
- Admin
[REMOVED BY REQUEST OF FORD]
I don't remember where I saw it last, but read that the Max Tow package includes additional cooling/components for the motors/batteries which obviously generate more heat for heavy towing.Over 100 pages information and the max tow package details are still just: "Increased trailer towing capacity"
I saw that too. Wondering if it on all models.So the Lightning has the active air dam…thought maybe it did but I had not seen it listed anywhere before.
I understand “keyless entry” to mean you use to fob to push the unlock button. Not the key in your pocket touch the door handle and it unlocks keyless. I believe that’s “Intelligent access” that requires the 312 package.I learned a few things
- Apparently your key fob will auto lock/unlock? Love this feature in my bolt as I can keep my keys in pocket at all times.. Here is what is says under standard pro features: "Door locks — power with flip key and integrated key transmitter keyless entry (incl. autolock)"
I think it must…it’s got to factor into the EPA rating so I would think it would have to be on all trim levels.I saw that too. Wondering if it on all models.
Damnit you might be right. Once you have the feature its hard to imagine going back. I always forget to lock my wifes SUV when i drive it.I understand “keyless entry” to mean you use to fob to push the unlock button. Not the key in your pocket touch the door handle and it unlocks keyless. I believe that’s “Intelligent access” that requires the 312 package.
“auto lock” means the truck will lock once you start moving, at 4mph.
I hope I’m wrong because that’s the #1 request from my wife and I don’t want to spend $8-10k more for it
