Louis
Lou
NW Pennsylvania
www.enormis.net
21 F150 Crew 3.5 Lariat Sport 502a 6.5bed FX4
Biz Owner
Stock offset is +44
I see he got a 17" OEM wheel on that 2021.... ummmmmm. I tried my winter 17" Ford OE wheel (that fit my 14 Lariat fine) and the 17" OE wheel WOULD NOT clear my 21 Lariat rear caliper.... FYI.
NoSnow
Ben
Northern Alberta
F150
Plastidip fellas. Did it myself. You can get it at Menards.
I like the option to peel it off to put the wheels back to stock if I decide to sell. Wheels and tools are the the only things I’ll use the stuff for, but it looks good and holds up great with good prep work.
Just make sure you pull the wheels and hand wash them, mask properly, and the lay on a lot of thin layers with minimum 30 minutes between coats and I think you’ll be impressed with the results.
Worst case scenario you don’t like it... Just peel it off!
Really great job. First time I've heard of Plastidip . You have got me thinking of some uses. If I wanted to blackout my rear bumper or the chrome caps on my tow mirrors do you think Platidip would be a good option?
TheWraith
TheWraith
Kevin
Burns Harbor,IN
2017 Ford F-150, 2020 Chevy Corvette, 2016 Ford Focus
Assembler
Does your truck have the Max Trailer Tow Package?
I know those trucks have bigger calipers then a standard Trucks
Louis
Lou
NW Pennsylvania
www.enormis.net
Biz Owner
YES, it has the MAX Trailer tow. good call
TheWraith
TheWraith
Kevin
Burns Harbor,IN
Assembler
Yes!!!
We solved it Louis!!!
Good to know tho thanks for heads up on that info!
Norris McCarty
Norris
San Angelo Texas
21 F150 Lariat 4x4 PB 7.2k FX4 17”Raptor Beadlocks
Own a RV dealership
Yes!!!
So, if I want to use the 17” Raptor wheels and tires, I do not want the Max Tow package......is this correct?
I suspect the rear brake rotor is larger diameter on the 9.75HD axle than the non HD 9.75?
Can anyone confirm?
Thanks
TheWraith
TheWraith
Kevin
Burns Harbor,IN
Assembler
Can anyone confirm?
Thanks
All I know is I'm happy we get a 9.75 Diff with that option, rest of F150s should have 8.8s haven't gotten under one and looked yet tho
Norris McCarty
Norris
San Angelo Texas
Own a RV dealership
I think all of the Powerboost axles are 9.75. I'm assuming the Maxtow pkg has the 9.75HD which has the larger rear brake rotors.
Maybe someone can clarify.
Norris McCarty
Norris
San Angelo Texas
Own a RV dealership
Do you have Max Tow on your Lariat?
Louis
Lou
NW Pennsylvania
www.enormis.net
Biz Owner
philraptor
Phil
Nevada
Tundra Trd
Attorney
Is it confirmed that all Powerboost trucks have the larger rear calipers too?
Norris McCarty
Norris
San Angelo Texas
Own a RV dealership
No…just those with MaxTow
The caliper is not larger…..the rotor is.
vdubbz
Louisiana
2021 f150 stx 2.7l
Thanks NiftyF150! It is awesome. Did you pay someone doing it? Can you post the link where you buy the spray if you did it yourself?
Hey I have the same wheels, I am trying to find the largest size tire for this without rubbing. Any help?
CaptainAmericaRob
Ed
2021 F-150 Lariat FX4 PB
Machine Designer - Ford Motor Co.
Hey, how has the plasti-dip held up since you put it on? i love the look.
