Reset your browser ZOOM level to 100%, I just double checked Chrome, it is zooming up OK to 400%I'm on my PC
Download the image, then use a photo viewer to look at the photo
Here is a condensed view, NOTE I hid all the vehicle spec's only showing you blend day and the sequence numbers assuming that is what you're interested in.I'm on my PC
Thank you. I was trying to figure out what build number the guys that got the build email were so I can see if there is any order to it.Here is a condensed view, NOTE I hid all the vehicle spec's only showing you blend day and the sequence numbers assuming that is what you're interested in.
No order to that situation, I thinks it is highly dependent on the condition of our build readiness, re-work, application of missing parts and programming the new TPMS program and how deep in the back lot your truck is in the holding coralThank you. I was trying to figure out what build number the guys that got the build email were so I can see if there is any order to it.
Not sure if i should reply here to let you know, or on the original thread. I looked for it, but couldnt find it. Either way, wanted to let you know I did it...No, I do not have you on my list yet, unless you recently reported your build information, please fill out the form noted in step 1, it will take several days for the forum sheet ADMIN to post new member data.
I import the information into my version and only update it from members written reports or research of VIN if you share your full VIN, you're not required to share the full VIN, but then I rely on your periodic updates.
1. Please use the Order Submission Form to add yourself to the list.
2. Post a reply in this thread to let us know.
3. Once your submission is approved it will show up in the list.
4. Be sure to check out the STATS sheet below for detailed infographics.
5. Use the Change Request Form for any changes to your order info.
3:44amWhat time did that email arrive in your in box?
This thread, DO NOT quote Post 1Not sure if i should reply here to let you know, or on the original thread. I looked for it, but couldnt find it. Either way, wanted to let you know I did it...
Sorry meant this
Each Ramp represents an Origin / Destination combination for Ford. Example my CM6P ramp is an Oklahoma City Rail destination. You can search google for Ford Ramp Codes and there are some lists that folks have attempted to collate. But CA46 is wherever your nearby rail destination is that Ford delivers vehicles from the Rouge.My ramp says CA46. What does that mean?
Thanks for the update, I can confirm your sticker is not coming back.
